Binance website problem
When I go to the website Binance.com, Brave is being detected as not being the correct size (I think). I get a bunch of code with the following first line.
{{“We’ve detected that you are using a small display”|T}} .
Is there a switch or something I can do to get this website to display correctly?
Thanks for your help.
Mick
Hi @olmbrav,
What version of Brave are you using currently?
I copied the following from the About Brave page of my Brave browser:
Brave: 0.24.0
V8: 6.9.427.23
rev: f657f15bf7e0e0c50a2b854c6b05edb59bfc556c
Muon: 8.1.6
OS Release: 10.0.17134
Update Channel: Release
OS Architecture: x64
Node.js: 7.9.0
Brave Sync: v1.4.2
libchromiumcontent: 69.0.3497.100
Thanks for the quick response and thanks for your help.
Mick
Thanks!
The Muon-based version of Brave (the version you’re using) and Bianance have a history of not playing nice with one another. Good news is I know how to solve this problem, follow these steps:
  1. Navigate to https://brave.com/download-beta
  2. Download Brave Beta
  3. Install and launch
  4. Enjoy your privacy :slight_smile:
Problem solved. Thanks.
Mick
