Basically, bet365 doesn’t really work with brave. It doesn’t load things, it won’t let you place a bet, it won’t show some numbers, it will suddenly stop loading and etc.
https://bet365.com/
Did the issue present with default Shields settings? (yes/no) yes
no
no
yes
Brave version (check About Brave
