I’m using Brave on Windows 10 with 3 different profiles, I enabled Rewards in all of them but for some reason they show different BAT balances and only one of them is reflected in Uphold.
Hi @steeven, thanks for the response. These 3 profiles, I’m using on Windows 10 2004 and Brave 1.12.114. I would like to add that I also installed Brave and enabled rewards on my notebook which uses PopOS 20.04 Linux yesterday. So I had 3 profiles and the problem was happening, but now I have 4 profiles.
I also would like to add that I formatted both of my PCs numerous times and installed Brave with rewards enabled in all of the new installations.
I don’t know if these details change something, but I think it makes more clear what kind of setup that I have.
@daniellmiranda,
Can you confirm that all of the first 3 profiles were linked to the same Uphold account? Additionally, if you disconnect/reconnect the wallet, does the balance adjust itself?
