Hi @labear . I’m starting to wonder if this particular issue isn’t Brave-specific. Judging by the screenshot it looks like there is an actual ‘bad certificate’ problem going on.
This could be on the site’s end, but that URL seems to have a valid certificate on it for me, as well as for the Brave rep you mentioned.
So, I’m wondering if it has something to do with the fact that you’re running Windows 7 which I believe is out of support; and as a consequence, may have outdated certificate authorities installed. Or, another possibility unfortunately, is that your machine is compromised; but for it to manifest this way would be somewhat unusual.
Hi again,
OK - Yes the untrusted-root URL did not open on Brave…got same pg as in screenshot.
And and globalsign.com URL opened just fine.
FYI - there is no recommendations for uncovering security settings, etc for Brave Browser on this page.
As for Win7 - sure, that is very possible. Though I’ve been unsupported for months and this just started 45 days ago. I have no plans to update this OS on this CPU…to old.
Though I can say this - both my Chrome & Firefox browsers are working great on this cpu and are considerably faster in loading pages compared to Brave the last 45 days.
That URL you gave never failed. It loaded the page pretty fast, but still after 5 min has not completed the load due to spinning graphic as you mentioned.
My Brave browser on my mobile had no issues w/ this page at all.
Bottom line is, Brave is getting what it considers an invalid certificate from the Chase site. The Globalsign link has a couple screenshots where you can see the certificate details, posting the details of the Chase certificate that is perceived by Brave might help explain why it thinks the cert is bad.
Firefox uses its own root certificates list, whereas Chrome uses the operating system’s, and I’m assuming Brave does as well, so I’m not sure why it would behave differently from Chrome… but in any case seeing the cert details I think will be important.
If you go to the Chase site throwing the error, hit the ‘Not Secure’ button and click on ‘Certificate.’ Then if you include screenshots from the ‘General’ and ‘Certification Path’ tabs from the window that pops up, I think that will help.
Here’s an example of the Cert Path tab from the badssl page’s cert:
Hello on the 4th of July,
I don’t expect a reply from you this weekend - ENJOY some relaxation.
As for screenshots you requested - see 4 attached files.
Once I opened the Cert screen & grabbed screenshot, I then opened the cert path and grabbed that too as requested.
But then I noticed that I could also open that for further details and screenshot 3 & 4 are that info.
In # 4 it says “This CA Root certificate is not trusted because it is not in the Trusted Root Certification Authorities store.”
So does this mean I need to install this cert myself into the “trusted Cert. Auth. store”?
I also went to bankofamerica.com and read that cert error - it was pretty much the same details.
Hey, thanks for the well-wishes, hope you had a good Independence Day as well.
To the original issue, yes, so this does appear to be a more general certificate issue with your computer. Trusted root certs are supposed to be delivered automatically via Windows Update. So first, I would make sure you are getting all available updates from Windows Update. If you still have the issue, then my guess is that no more updates are being provided due to the ‘out of support’ situation with Windows 7.
If you find yourself in a dead-end due to that, then yes, you could install that individual root cert. But over time this problem will get worse and you’ll continue to play whack-a-mole. I know you said you don’t want to upgrade to Windows 10, but might be something to reconsider, even if there will be a performance degradation; the security benefits (not just because of certs, but a ton of advantages vs. Win7) would be worth the trade-off IMHO.
Hi,
I agree re " whack-a-mole" term. Though isn’t a CPU a whack-a-mole anyhow?
If I’d like to install the trusted cert myself, can you suggest any good references for me to do just that.
This is one area of CPU’s I’ve never entered over my 35+ yrs of computers.
But before doing that, you’ll need to first export it, and that doc doesn’t show that part of the process. Basically you’ll just have to go to the certificate details as before (like in your screenshots), and make sure you’re viewing the highest-level cert listed there. Under the Details tab of that cert, you should have a button to save it to a file. Choose an export format (probably doesn’t matter which you use, but try the default first, and then the 2nd option if that doesn’t work later on import) to save it to, and then try the Import process from the link above.
You’re a genius.
Wow, that was a fun experience.
I was able to get pretty much all of the important sites resolved.
I still have two sites in error, one of which is a life insurance company the other is a mobile phone company both have certificates that show as either “non-trusted” or “cannot verify”. I tried installing anyhow and still sites in error.
Any thoughts if there’s anything I can do about those?
And lastly in regards to the Brave browser; can you recommend anything to resolve the “waiting for cache” browser notice (lower-left-corner) I get occasionally when moving from site to site (browser frozen waiting for that to clear)?
Is there a way to increase Brave cache allocation size, or clear more often in background after x-many sites viewed?
Sorry, not sure about the ‘waiting for cache’ thing, I wonder if there is anything you could improve on the general operating system performance side of things (e.g., add memory, close other large apps, etc.) that might help… and also make sure you’re not running out of disk space.
Regarding the last two sites, it could be a similar issue with intermediate certs – in other words, a level down from the root certs you already took care of. If so, basically it’d be the same process you followed earlier, except instead of exporting/importing the top-most certificate you’d pick the next level down, and continue that all the way down until the issue is resolved. (Probably won’t be more than 1 or 2 per site.)
If that doesn’t fix it feel free to post more screenshots showing the issue in case it’s a different problem.
