Hello it seems Brave has to be missing some features.
When I repeated some vocabulary on home.babbel.com today, it didn’t work properly.
Normally I write a real vocal. Then the written text is read from the page. With the beta of Brave this does not happen, it is forwarded directly to the next vocabulary.
I checked the whole thing about Microsoft Edge (if the website owners changed anything), because it is played there.
Translated with www.DeepL.com/Translator
hey Am facing the same problem. Hope anyone here can help me too.
Thanks in advance. Regards,
https://akinator.ooo/ https://xender.vip/ https://kik.onl/
@MediaBird, can you ensure that you have the proper region settings on the OS level? For windows, this would be the “Region control panel”.
What does right mean? I use German as the language on my operating system.
The problem seems to come from Babbel himself. Here is the message I received:
"Hello,
Thank you very much for your message.
Please note the system requirements that apply to our learning program.
As far as browsers are concerned, a current version of Chrome, Firefox, Edge, Safari or Internet Explorer is required.
The browser Brave you are using is not currently one of these, so I cannot promise that the program will run smoothly.
We will gladly pass on your suggestion to offer alternative browsers to the developers so that they can evaluate it there."
@Mattches @jasonsmith
The problem is the Auto-Play Blocker.
The solution is for the vocabulary to be read aloud;
home.babbel.com call
Click on Repeat Vocabulary
Repeat a vocabulary
Then the message appears on the URL bar that Autoplay has been blocked.
Click there and select “Always allow autoplay on https://my.babbel.com”.
