Autofill capitalization problem
Not sure if this is the right place for this. I have autofill enabled. Whenever I am prompted to use autofill, it fills with all lowercase in my name, city, etc. The prompt shows my first name lowercase, but underneath it shows my full name capitalized correctly, no other choices in the prompt. I’ve gone in and edited to make sure the only entry has everything capitalized, but it still fills with lowercase. What do I need to do to have it fill properly?
@JohnN what OS are you seeing this on?
Windows 10. Pro, if that matters
The only way this can happen is:
  1. If you have it saved in autofill with that specific capitalization (or lack thereof)
  2. There is some Windows system setting that is affecting this behavior
My money is on the former and I would recommend simply deleting those specific autofill entries from the browser and re-entering/saving them with the desired capitalization.
As stated, I did go in and edit. I even put South instead of So in address, just so there was something to change/save. I have a few things to bookmark and close. That’s the only thing I have not done after the edit, was to restart browser.
Rather than edit them, I’m asking you to completely delete the entries. Then re-enter them and see if you get the same results.
I’ll give it a try. Have to go find some page with a form now. I’ll try this before restart just to separate attempts to which one, if either, works. Thanks for the assist. I’ll post back when I’ve done both.
Delete and add again worked. Not sure if restart would have helped, but this worked. Maybe I should have tried that first. Anyway, Thanks for the help.
