Auto-contribution: how does it work?
Dear Community
It is unclear to me how auto-contribution works.
How are the rewards distributed?
Is it based on the pages you visit?
Is it randomly distributed?
Is the amount somehow proportional to your balance?
There are rumours that unverified devices will work the same way starting with release 1.48.
Are they going to have auto-contribution on by default? Or are they going to work differently? If so, how different?
Cheers,
A
iirc bat generated each month is split and contributed to the verified publishers / sites you have visited based on time spent consuming their content.
and yes unverified will be essentially on auto contribute soon. however vbat held before the switch can be tipped as normal.
