When I play audio on websites (Youtube is an example), the audio plays fine when I hit play button (I have autoplay turned off). When I then go to adjust the volume level using the Youtube widget on the video, it stops the playing. I then have to restart the playing and to hear the adjusted audio level playing again.
Go to Youtube, with latest Brave Version:
Version 1.18.78 Chromium: 87.0.4280.141 (Official Build) (64-bit)
Then play a video, (I have autoplay off). Now adjust the volume using widget in the Youtube video planel. When I do this the video stops playing.
video stops when adjusting volume
video should keep playing as it does in firefox.
Everytime
page in the main menu):
Edition | Windows 10 Home |
Version | 20H2 |
Installed on | 7/24/2020 |
OS build | 19042.746 |
Experience | Windows Feature Experience Pack 120.2212.551.0 |
It also does this on other video sites besides Youtube.
