Asus Japan Store images will not load (default shields)
Asus’s Japan store website does not load any images with Brave shields (specifically the cross site trackers/ads) on.
https://jp.store.asus.com/
Yes, default settings.
Site functions as normal when shields are off. (images are displayed)
Yes, cross tracking/ads.
The site does work as expected in Chrome.
Version 0.68.132
Screenshots of shields OFF and ON
cc @fanboynz in case there’s something that can be done from Brave side.
Have submitted a fix, needs to be approved first.
Eljuno, thank you for the help and CCing fanboy.
Fanboy, thanks so much! You’re the man!
You’re all awesome!
