Ardmediathek.de does not load anymore
https://www.ardmediathek.de/ard/ reports the following error message
This page isn’t working
www.ardmediathek.de redirected you too many times.
ERR_TOO_MANY_REDIRECTS
Just type in URL
ardmediathek should show
For the past hour
Windows 10 build 1903
Brave Version 0.66.99 Chromium: 75.0.3770.100 (Official Build) (64-bit)
Hi,
the site works for me (https://www.ardmediathek.de/ard/). Could you follow the tip of the page and delete your cookies if necessary?
chrome://settings/clearBrowserData
Copy this to the URL page & press Enter.
At Period you choose “Total time”. The option “Cookies and other website data” should be checked - > click “Delete data now”.
Just tested in Brave, Brave Beta and Nightly;
https://www.ardmediathek.de/ard/player/Y3JpZDovL2Rhc2Vyc3RlLmRlL2ZpbG1kZWLDvHQgaW0gZXJzdGVuLzk4ZTQ2ZTJkLTM4OTctNGZkOC1hMGIxLWIzNzdiMDA4N2YwYg/die-beste-aller-welten-poster
Seems fine?
Odd…I had removed the cookies but that didn’t help.
I needed to use the Advanced cookie cleaning to make it work again.(Or use a VPN connection)
It is working again now. Thank you
