Appearance Toggles in Settings do not react to second click
Description of the issue: Following appearance toggles in Settings only work first time you click them, rather than a toggle (click -> on | click ->off) they act as a one time switch (on OR off):
  • Show home button
  • Use wide address bar
  • Show bookmarks bar
  1. Navigate to Brave Settings -> Appearance
  2. Click on Show home button, home button will become visible (or invisible if your previous toggle state was visible)
  3. Click on Show home button again
If home button was previously visible, after step 3, button should become invisible
If home button was previously invisible, after step 3, button should become visible
Brave Version:
Version 1.0.1 Chromium: 78.0.3904.108 (Official Build) (64-bit)
Issue is reproducible on Windows 10 Pro but is not reproducible on macOS Mojave.
