Appearance issue (system min/max/close overlays extensions) -- vertical tabs / show title bar -- related
Appearance issue (system min/max/close overlays extensions & hamburger) when vertical tabs enabled without enabling “Show title bar”, on at least QT theme.
  1. Enable vertical tabs, without “Show title bar”.
  2. Switch Appearance Theme to QT
  3. Toggle Tabs (> Use vertical tabs:) > Show title bar – on & off.
Expected result: extensions & hamburger menu are not blocked by window controls
Brave Version( check About Brave): 1.71.123 Chromium: 130.0.6723.116 (Official Build) (64-bit)
Top, blue spiral profile, shows issue (Show title bar – False). Bottom, purple spiral shows expected (Show title bar – True).
