Andriod Broswer click setting result with blur screen in device
Upon clicking the broswer’s settings button, the device would turn blurry as in the pixel of text shift horizontally (not only the broswer but the entire display on device). The only solution to it is to restart the device.
Searching the internet with similar problem only results in desktop version with advice that turns off “Hardware accelaration”, but I couldn’t find the setting in mobile version of brave.
  1. Open Brave
  2. Click settings
Blurred screen on device
1.60.125
Mobile Device details
HP Chromebook 14B-NB0015CL
running on ChromeOS Version 119.0.6045.158 (Official Build) (64-bit)
I had both Brave and ChromeOS set to auto update, so I couldn’t tell which update broke the broswer. It used to be able to click seetings just fine until a month or two ago.
I also encounter another problem that wouldn’t play video normally that I created another post for the sake of easy searching.
And Thank you for the hardwork :slight_smile:
