An error occurred while checking for updates: Installation failed due to unspecified error. If Brave is currently running, please close it and try again. (error code 7: 0X80040902: 7 -- system level)
  1. Cannot use about>update results in error
  2. Tried to do a standalone installation as well and it starts then says there is anrror
Source of info:
https://support.google.com/chrome/thread/203737950/when-trying-to-update-chrome-i-get-error-code-7-0x80040902-1073741571-system-level?hl=en
emasterbuild(not reliable by my own admission)
Feb 26, 2023
Error code 7: 0x80040902 is usually caused by corrupted or incomplete installation files of Chrome. Here are a few solutions you can try:
Use the Chrome Cleanup Tool: Google provides a free tool called Chrome Cleanup Tool that can fix installation issues and remove software that may cause Chrome to crash or display unwanted ads. You can download the tool from Google’s website and run it to scan and remove any issues.
Check for malware: Malware or viruses on your computer can cause issues with software installations. Make sure your computer is scanned for malware and viruses using a reliable antivirus program.
Run Chrome as an administrator: Right-click on the Chrome shortcut and select “Run as administrator”. This will give Chrome the necessary permissions to perform installation or update operations.
Check your internet connection: Slow or unstable internet connection can cause installation issues. Make sure your internet connection is stable and fast enough to download installation files.
Disable antivirus software: Antivirus software may block or interfere with Chrome installation or update. Try disabling your antivirus software temporarily and see if the installation or update goes through.
Source: https://www.thewindowsclub.com/fix-error-0x80040902-during-google-chrome-update
Fix Error 0x80040902 during Google Chrome update
While updating Google Chrome on Windows 11/10, if you get error code 0x80040902, this article will help you fix the issue. Although it is an unusual error, you may encounter this issue on your computer with any version of Google Chrome.
To fix error 0x80040902 during Google Chrome update, follow these steps
  1. Close all tasks and restart Chrome
  2. Disable VPN and proxy
  3. Disable antivirus/firewall software temporarily
  4. Reset Google Chrome
  5. Reinstall Chrome
Worth a visit to that website - good illustrations.
