@iamb9 comidoc.net
is fixed, give it 24-48hrs.
(also see my response regarding the others)
Thanks for the FIX
Hello,
Your search engine results have become better than before. Please introduce a feature in Brave Desktop to choose different search engines in normal and private mode. Let me explain you why it is needed. I donât like DuckDuckGo search results but I have to keep DuckDuckGo as a search engine due to the privacy extension. I have installed it as it provides a two layer security for me. If some trackers escape Brave Shield then it is blocked by DuckDuckGo extension, I myself have experienced it. Once it showed me 2 trackers blocked in spite of Brave Shield being active. If you would introduce different search engine for private tab then it would be beneficial for me as well as for others. For my accounts and all I will get 2 layer protection and for good search results I would use private window only with Brave Search as my search engine. Hope you get my point.
Thank You,
Mohak
Hey, the website âtviplayer.iol.ptâ has now started blocking Braveâs ad-blocking feature: the videos across the website wonât load/be displayed unless the browserâs protection tools are disabled. (I donât know if this is the most appropriate place to report thisâŚ). Could someone please take a look into it? Thank you very much in advance.
