Ads are showing, but the earnings are stuck, not increasing... Help
Briefly describe your issue:
Ads are showing, but the earnings are stuck, not increasing… Help.
MacOS, Version 1.25.72 Chromium: 91.0.4472.101 (Official Build) (x86_64)
no
Yes, but it has stopped for months.
Are you using a VPN? (yes/no)
yes
yes
yes
Hi, @zeby , you’re likely having this issue because you are using a VPN. Please visit this page and read it thoroughly.
Hi, thanks for the reply. I do need VPN on a daily basis in order to access certain websites, not " for the purpose of downloading ad catalogs from other countries." If it’s not allowed, is there a way for Brave to bypass the VPN connection, thanks!
I understand.
Unfortunately, at this time there isn’t. Users must decide which is more important to them, receiving Brave Rewards or using a VPN. :confused:
Hmm, ok, then. Thank you. :neutral_face:
The VPN is blocking the ads catalog from refilling automatically. There is a workaround that you will have to perform once per day (the catalog holds about a day’s worth of ads):
  1. Temporarily disable the VPN
  2. Close and reopen Brave
  3. Wait until you start seeing notification ads (5-15 minutes)
  4. Renable your VPN
There is no issue with using a VPN with Brave as long as you are using only VPN servers in the region in which you are actually located.
