In Android 11, there is a category of settings in the accessibility suite called ‘interaction and dexterity’. Within that category is an accessibility setting that customizes the touch duration required to activate the ‘touch and hold’ trigger systemwide. Here is a screenshot.
I get very shaky sometimes, which makes it difficult for me to trigger a touch and hold event under those circumstances. The shaking registers as multiple taps, because technically that’s what I’m doing. So I have the setting customized to shrink the trigger down to a duration I find comfortable to use. It works in other apps like Firefox and such, but for some reason Brave is ignoring the setting and using the default tap and hold duration. Can this be looked into please?
1.35.101
Mobile Device details
Samsung Galaxy Note 20 Ultra on Android 11.
The setting seems to be applied to tool tips, browser menus, etc. For instance if I long press on one of the squares in my top sites after opening a new tab, Brave honors the accessibility setting and uses my customized long press duration. But if I am on a webpage and try to long press a link, image, text, etc, the setting is ignored and the default value is used.
@Mattches When you get a moment, could you look into this? Upon further inspection, the behavior actually seems to be the same in Firefox. It works when interacting with the browser, but not when interacting with a webpage.
