Hi folks, having an issue with this website. I believe the Shields might be blocking elements that aren’t blocked on other adblockers.
Not able to listen to the live stream with the default Shield settings turned on. It works without shields on and on other browsers using extensions like uBlock Origin. In order to start listening to the live broadcast, you must need hit the play button in the red box on the top right corner. A video ad (that I believe is usually whitelisted with most or all Adblock apps) pops up and plays before the broadcast starts. With Brave shields up, this ad is blocked and does not pop up. I’ve tried allowing pops, fingerprinting, etc. and to no avail.
Yes
Yes
It breaks with the default Shields configuration turned on
Yes
Brave version (check About Brave
v 1.41.100
